applying mask filter
  • applying mask filter
    im trying to put a smooth blur over just someones mouth. i seem to remember that you use mask for this, i click inside filter, i draw a rectangle around the area to be blurred and then i pick smooth blur and adjust it. nothing happens...
    i thought this was how its done, i seem to remember last time i did it after i drew the rectangle, you saw the dotted lines stay there, then apply the blur, thats not happening either, has to be something simple im missing]
    thanks
    Maybe a missed check box to actually apply the mask.?
    Sys1: Gigabyte Z370 HD3 i7 8086K(4.3Ghz), 16Gb ram, 256Gb SSD system + 2x2Tb Graphics: nVidia 1060, (W10 Pro) BM IP4K, E8v3 WG; Vegas Pro19; Davinci Resolve18_Studio, GH2(hacked), Pana HC-X2000E, GoPro5
    Sys2 :Clevo i7 6700K 2.5Ghz,16Gb ram 2565Gb SSD + 1Tb, (W10 Pro), Software: E8v3 WG; Vegas Pro19,Davinci Resolve18_Studio
      you will not see any changes in the mask preview monitor, that is normal
      changes are seen in EDIUS REC Mon or external Mon
        You should use Gaussian Blur. The effect will show up in the Mask preview monitor but you have to set it up. In the Mask Box look at the top buttons (icons) and find Function (looks like a Grid). When opened click on the first 2 options (you have to do one at a time). One allows the effects to be seen, the other allows the alpha channel checkerboard to be seen.
