Hello
An issue and a suggestion.
I have some iPhone UHD 50p HEVC footage. As my PC is Xeon based I don't have Intel Quick-sync to help playback. Indeed the footage won't playback.
The resolution drop down doesn't help, it doesn't do anything in this instance.
I don't know whether that can be looked at for MP4/H265 files in this configuration of PC by GV? (Would help quite a few AMD CPU users too)
That's another issue - I digress.
So my choice is that I either render those clips out to HQX or use Proxy Mode.
However I want to mix those clips in with other material that will play OK, so what I wanted to do was to only have a group of clips in the Bin or a bin folder's worth of clips in Proxy Mode. I would be quite happy to have a Bin folder with only that footage in to be able to do that.
Making the whole time line Proxy Mode when most of the clips play OK in my mind spoils the experience, wastes rendering time and disc space unnecessarily.
Is there any merit in this idea of being able to apply Proxy Mode to all the clips of a difficult to play type in a Bin folder (add a Bin button to do this) rather than having Proxy Mode globally applied to the whole project?
This idea could be extended to a right click on a clip on the timeline that had say difficult to play plugin filters added. An on/off toggle or box tick would be needed.
There would need to be a clear all proxies button in the sequence settings.
Somebody might have a better idea, but there it is, any good?
Regards
Regards
