Edius Pro 8.53 - Editing 4K 3840x2160 - film slow sound stuttering
  • Edius Pro 8.53 - Editing 4K 3840x2160 - film slow sound stuttering
    I now have a Sony A6500 camera and even editing a short one minute length 4K file is just impossible, because even after rendering which takes about nearly 6 minutes, if I make any small change the slow film and stuttering is back. Is this because my computer is not up to 4K editing (info below)?
    I know the Edius Workgroup has the function to lower the viewing screen resolution, but is there a workaround for that in my Pro version?
    INFO:
    NVIDIA GeForce GTX750Ti Driver Date 13/09/2021 Version 30.0.14 7212
    OS Name Microsoft Windows 10 Home Version 10.0.19042 Build 19042
    Other OS Description Not Available
    OS Manufacturer Microsoft Corporation
    System Name DESKTOP-4NMG8TF
    System Manufacturer Dell Inc.
    System Model XPS 8900
    System Type x64-based PC
    System SKU 06B8
    Processor Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz, 3408 Mhz, 4 Core(s), 8 Logical Processor(s)
    BIOS Version/Date Dell Inc. 2.7.1, 22/11/2019
    SMBIOS Version 2.8
    Embedded Controller Version 255.255
    BIOS Mode UEFI
    BaseBoard Manufacturer Dell Inc.
    BaseBoard Product 0XJ8C4
    BaseBoard Version A00
    Platform Role Desktop
    Secure Boot State Off
    PCR7 Configuration Elevation Required to View
    Windows Directory C:\WINDOWS
    System Directory C:\WINDOWS\system32
    Boot Device \Device\HarddiskVolume2
    Locale United Kingdom
    Hardware Abstraction Layer Version = "10.0.19041.1151"
    Username DESKTOP-4NMG8TF\Dell
    Time Zone GMT Standard Time
    Installed Physical Memory (RAM) 16.0 GB
    Total Physical Memory 15.9 GB
    Available Physical Memory 11.3 GB
    Total Virtual Memory 18.3 GB
    Available Virtual Memory 12.6 GB
    Page File Space 2.38 GB
    Page File C:\pagefile.sys
    Kernel DMA Protection Off
    Virtualisation-based security Not enabled
    Device Encryption Support Elevation Required to View
    Hyper-V - VM Monitor Mode Extensions Yes
    Hyper-V - Second Level Address Translation Extensions Yes
    Hyper-V - Virtualisation Enabled in Firmware Yes
    Hyper-V - Data Execution Protection Yes
    Edius Pro 8.52 - TAW5
    in the EDIUS bin, convert any or all such clips to Grass Valley HQX and they will play realtime and editing will be smooth
    some UHD files are H265 and even my PC with 32 cores can struggle, but in EDIUS9 or X you can lower preview resolution to get better realtime
    can you provide a screenshot of your project settings and a screenshot of such a UHD clip as viewed with mediainfo (free) in tree view in order to spot possible config issue
      Thanks Anton. I don't know what a UHD clip is, but presume its just the 4K file and I guess you have photoshop so the attached file is a psd with 4 layers of which 3 are from Mediainfo.
      Its nearly 0230 hours here in the UK and so I have to go to bed now as I'm up again in 5 hours time so if you answer, it will be some time before I can answer any more questions.
      Looks like the attachment upload does not like psd files and so I have now uploaded 4 jpg files.
        3840x2160 = UHD (it is not 4k)
        you are shooting UHD 50p and editing UHD 50p, your PC will not handle that unless you convert the clips to HQX
        your project setting is set to 8 channel audio = 7.1 surround sound
        I think you should set to stereo, 2 channel
        attached are the correct project settings
          Many thanks for your help Anton, it is much appreciated.
            If you are using 8bit H.265, the 6700k should decode that.
            Converting to HQX will help quite a bit. If it is still sluggish, you can change your 3840x2160 50p project by adding Lanczos 3 Hi Quality in the settings.
            Then change the frame size to 1920x1080. This will help with playback. When you have completed the editing, just change the frame size
            back to 3840x2160 and export.
            There is also an Edius 8.53 update available.
