Audio filter question
  • Audio filter question
    I see a "Delay" effect in the audio effects but is there a reverb? I am sure there was one in previous versions of Edius or will I need to purchase a plug in?
    I need to add reverb to some sticks being hit an an Australian Aboriginal Welcome to Country.
    thanks
    If you have EDIUS X, then the answer is yes
      oops, I think you mean to add it rather than remove it?
        Yes Anton, I want to add reverb. I have Edius X.
          check here
          Hi everyone. I have a client that needs me to add some "natural" sounding reverb to some video/audio clips I recorded for her. I'm using Edius X, and I don't see any audio filters that can do that. The Acorn filters allow you to de-reverb very effectively, but not add reverb. What does everyone recommend to add
            Acon Digital Verberate is an algorithmic reverb plug-in that simulates real acoustical spaces with a new degree of realism. Verberate is available for PC and Macintosh and supports the VST, AAX and AU plug-in formats. Both 32 bit and 64 bit versions are available.
