Quick Titler quick question
  • Quick Titler quick question
    Is there a way in Quick Titler to create a shortcut for "Layout/Centre in screen/Horizontally?
    We are doing closed captions on a job and its annoying having to re centre all the time.
    Also when editing text the text is fuzzy until you save the file and get out of Quick Titler. I thought there was a short cut to make the text clear so therefore when you are editing its not so hard to read.
    Quick Titler has poor compatibility with Chinese input methods and often misses Pinyin letters,This problem exists from EDIUS 8.2 to 10.21.Feedback many times, problem cannot be solved。
    This is a shortcut
    jpg
    CPU:AMD R9 5950X GPU:GTX1050 MEM: Micron 4G DDR4 2400x4
    motherboard:ASrock X570 matx
    SSD:intel p3600 sata HDD: HGST 8Tx5 raid0
    Power:Great Wall EPS2000BL 2000W
    OS WIN10 20H2
      A) We are doing closed captions on a job and its annoying having to re centre all the time.
      B) Also when editing text the text is fuzzy until you save the file and get out of Quick Titler. I thought there was a short cut to make the text clear so therefore when you are editing its not so hard to read.
      Hi:
      A)
      1) See screenshot-3: First, under Ansicht (=View), check the box (red arrowhead).
      2) See screenshot-4: This will display the red bordered selection box in the bottom right corner, where specific placement locations can be selected with the mouse.
      Remark:
      QuickTitler does not remember the checkmark set under A1). Must be set again at every QuickTitler restart.
      B)
      See screenshot-5: Check VorschauModus (= PreviewMode) or use Ctrl+Shift+F3. QuickTitler will remember this checkmark if once set.
      kurt
      Intel core i7-6700K / ASUS Z170A / 32 GB RAM / Intel HD Graphics 530 / SSD Systemdrive / Gigabyte GeForce GT 1070 / Win-10/64 Pro / EdiusX-WG (10.21)/ Mercalli (V2, V4 and V5 Plugin/64bit) / Resolve-17.4.10004 Studio / ImgBurn / PowerDVD etc.
      // Read > Test > Understand
        Alternatively, once you have a title you like you could copy and paste it, edit the copy and then "save as" and it the second copy will be different from the first. So make one with the text in the right place and centre tabbed and then re-user that. If you just save it will overwrite the original but save as or auto save asmakes a new one.
          Thanks all, that's a great help
