Piotr, well I am must say it's true that one can live and learn some more each day... I have never experimented any more with the graphics cards's HDTV preview having the perfect solution in the NX but this sounds very good indeed and would save much expense and messing with the computer innards.
Just one thing that still puzzles me and that is the 100Hz refresh rate you are using... from what I understand and forgive me if I am wrong but I believe that 100Hz LCD and Plasma HDTV's are not the same as CRT TV's that have a timebase that runs at 100Hz with subsequent improvement to flicker, in fact they run at 50Hz but "invent" their own intermediate frames that are interspersed with the true frames in an attempt to "smooth" motion.
If this is true then it's similar to the "frame blending" switch in After Effects that smooths motion such as might be employed in a format conversion from PAL to NTSC and I know for a fact that this is a very undesirable thing to have to do if you want to see your video as it was filmed.
Maybe something to check up on, I could be wrong perhaps your tv is true 100Hz.
