Can I use Edius X transitions in Edius 9
  • Can I use Edius X transitions in Edius 9
    I have Edius X but cant use it because my computer does not have AVX2 so..I still edit in Edius 9 Can I import Edius X transitions into Vers 9
    You can but you must first install X in order to install the free bonus transitions
    and because you don't have AVX2, you won't be able to install X, catch 22
      Thanks for getting back. I have X running on a different computer. Is there a way to copy and paste those working X transitions and paste them into Edius 9 on the non AVX2 computer ? Maybe by after effects bridge type method or such ? The Edius 9 computer is a strong custom build. Older... but works very well with Edius 9. It is my best computer. Edius X lives (and works OK ) in a cheap HP desktop PC.
        yes you can, copy these EDIUS X transitions from the EDIUS X Plugins folder to 9 Plugins folder
