Need advice on install
  • Need advice on install
    Hi
    I got my full 4 Pro package from the dealer the other day - I believe it's ver. 4.5 that is inside.
    I have 2 PC's where I installed the trial, which I think is the broadcast, and I have only 2 weeks left or so.
    Should I uninstall the trial on them and install the 4.5 from the package, or can I get a 4.6, non trial, somewhere, and should I be concerned about the 4.6 'expired issue'?
    I have read that there should be a 4.61 out soon. Should I work on my trial until that comes out, if it will be rel. in a week or so?
    Someone here in Denmark told me, that I could continue working on my trial if I just inserted the USB-dongle, but could this be if the trial is a broadcast?
    Thanks for any input.
    /Ulf
    Best regards * Ulf * Denmark
    mail to me
    The trial will not be broadcast unless the the dongle is broadcast.
    The upgrade problems have not hit everybody, I did the upgrade to 4.6 from the DL off of the website and it worked fine.
    So, I would suggest uninstalling your trial, installing the disk you got and then upgrading. If the upgrade doesn't work then use what is on the disk until 4.61 :)
      Thanks Mike - I'll give it a go in that way :-)
      /Ulf
      mail to me
