Edius render engine starts running but there is nothing to render
  • Edius render engine starts running but there is nothing to render
    This has happened to me 3 times the past weeks, I start up Edius X pro and the fans from my pc start to rev up. When I check task manager I see that the Edius rendering engine is active but there is no render task in the job monitor. To stop it I have to kill the process in the task manager. If I restart edius everything is normal again. Anyone has had this issue or knows what is causing this behaviour?
    you need to enable all display types to see what it is rendering, it could be doing waveforms
    https://www.videoproductions.com.au/...play-types.png
      Thx, I have all display types checked now, next time the render engine starts up for no appparant reason I hopefully should be able to see what is going on.
