Edius X not importing .wav files into project
    actually the other tread was more accurate disscussing the issue of "codec unsupported" media files import from the network meta-sans media drive.
      I am still having this same issue. Every other drive loads fine in Edius X but our SANs drive. All video, audio and graphics can load directly from the SANs drive into AFX and Davinci Resolve 17 on my PC (same PC with Edius X) without a problem. Also our Edius 7 and Edius 9 workstations load media files from the SANs with out the "Codec type not supported" error. The only Program on my PC having any problem loading from the SANs is Edius X. Clearly the Codec is supported from every other drive, so that is not the issue. And yes I could move the media to another drive to edit in Edius X, but there is 5 years of footage and 14TB of infomation on pur SANs.
        quick thought, current Edius X Workgroup version on my PC 10.20.7821, could this be "rolled back" to the previous build of Edius X Workgroup?
        As I said before Edius X did not have this issue when it was first installed and ran for several weeks loading from the SANs drive without this problem.
          yes, uninstall ans click "do not deactivate" when asked
          then install the previous version
          should all be done within 3minutes, no need for reboot
