Edius X not importing .wav files into project
  • Edius X not importing .wav files into project
    So I am editing on Win 10, Eduis X, and its saying .wav files are not supported ??? This is a major issue.
    Post a screenshot of your wav PROPERTIES and/or share a sample for others to test.
      seems to be an issue with the meta-sans attached to our network, unable to import anythig into Edius X from that source
        Where is this wav file coming from? Recorder or?
        JoiCam´s
        And more
          Are you sure it is a wav file? If show extensions is turned off in Windows then the waveform cache will look like a .wav file as it is audio.wav.ecw. So you might actually not be loading the sound file.
            OK after futher checking, i can get .wav and video files from my USB drives and system internal Media Drive. However our company uses a Meta-Sans network drive for B-roll fotage from multi-users (Tiger Store).
            Last week I used media from the Network drive (Tiger Store) in Edius X projects without problem. This morning I try and get Codec unsupport (error in Edius X) on any media audio or video from the network Drive. However I can move the network drive media to my desktop and USB drives with no issue. Also if I open a Edius X project from last week, the network Media in that older project works is loaded and plans fine. The only change I see systemwise is tha Edius X Workgroup updated from version 10.20.7620 to version 10.20.7821 over the weekend. BTW in Edius X Workgroup, can you turn off version updates somewhere? Screen captures show the difference uploading media from the same network drive (K) in the two versions.
              WG updates are done manually NOT automatically.
                There is no auto update in edius, someone did it manually because that is the only way updating Edius
                JoiCam´s
                And more
                  Thanks everyone for the replies, as no one has used this PC but me, the version must have been always 10.20.7821 then. However that makes this issue even stranger as the "Codec Unsupported" did not appear in my projects from the same network drive last week when I installed Efdius X and used it. edius X working 10.20.7620 same drive files.jpg unsupported error Edius X 10.20.7821.jpg
                    does the Clip0099.MXF work if you copy it from network drive to local drive and then add it to the bin and timeline?
                    • Dave M
                      Dave M commented
                      Editing a comment
                      Yes, I move to other connected drives and the files load fine in Edius X
                    Doe you know which codec is used?
                    • Dave M
                      Dave M commented
                      Editing a comment
                      mostly xavc, mts, avchd.
                    Are you at a TV station? Does other type of clips work from that drive? Are you making sure the drive is being read by Windows? Go to This PC and make sure you can see that drive.
                    • Dave M
                      Dave M commented
                      Editing a comment
                      Hi Pat, Yes TV station, 3 other work stations on Windows 10 with Edius 7 and Edius 9 load files from the same network drive with no issue. Windows 10 sees and cam move file to all my PC drive. Only Edius X having this problem.
                    Yes I can copy media files from the Network Meta-Sans (Tiger Store) to any other drives and Edius X loads these files as normal. All clips and Media files from the Meta-Sans are marked "Unsupported Codec" when trying to load in Edius X, but the same media files open in Davinci Rsolve, Adobe AFX without issue. Windows 10 sees the Meta-Sans without issue on all 4 of our Edius Workstations. BTW I am the Senior Editor at a Cable TV Station, we have Edius 7 & Edius 9 on the other PCs, only Edius X is having this problem (started this week, no problem last loading these Meta-Sans media files last week).
                      BTW there are two posts about this issue by me, how can I delete a post on the Forum?
                        I will delete the other thread.
