On daily news stories, I will set all of my raw clips as a sequence, then go through the footage and mark the beginning of each shot with a shot marker so I can easily jump from shot to shot in the source monitor. My problem arises when I make a few edits onto a timeline before setting all of the shot markers (say, a-rolling a story before marking the footage, then doing the shot marking before I start b-rolling) then go through the footage and mark everything, then Match Frame back from one of the clips that I edited onto the timeline before placing the rest of my markers. The Match Frame takes me to not just the position on my source monitor "tape," but also the status that that source was in at the time that the clip was laid to the timeline...so if I'd only set three markers before placing a soundbite, proceeded to add another 100 markers later, and then match framed that soundbite, it would take me to the raw footage as it was when I laid the soundbite...with only three markers laid on the sequence instead of 103. This has often had the effect of wiping out 30-plus minutes of shot marking effort, as I haven't found a way to recover the fully marked raw sequence unless I happen to have another clip on the timeline that was placed after I finished my marking. If you *do* have a clip that was put down after you were done with your markings, using match frame will bring the raw sequence up with all of the markers in place. But if you don't...you're kind of hosed. When I think of it, I try to make a "marker" junk timeline where I lay a couple of seconds of video after I finish all of my markers so I have something to use as a match frame if I accidentally wipe them all out, but sometimes I fail to do that. Is there another way to recover my fully-marked raw footage sequence when I've accidentally match-framed to a sequence that didn't have those markings yet? Is there a fix in the works where match frame will just point to the source timeline as it is now, rather than how it was when that clip was placed on the timeline?
Thanks!
Thanks!
