Trouble setting audio to left or right speaker.. Both tracks playing left only
  • Trouble setting audio to left or right speaker.. Both tracks playing left only
    Hey guys, so I moved some audio on my timeline and now both tracks are playing left only instead of one of each?
    how do i fix this?
    thanks in advance
    www.skysimonephotography.com
    www.skysimonefilm.com
    www.facebook.com/skysimonephoto
    Laptop:
    ASUS - 17.3" Gaming Laptop - Intel Core i7 - 16GB Memory - NVIDIA GeForce GTX 1050 - 1TB Hard Drive + 256GB SSD - Metal Star Gray
    Edius Pro 9 Windows 10
    Just to elaborate, so when I added music to the timeline, it puts the track on 2 different track lines on edius and it plays fine for stereo
    but at some point i accidentally deleted one of the layers, and now when I copy the layer i have left to another one,
    they both play left..
    is there a way to manually split to right? how do I fix it?
    I've tried right clicking on the audio options and nothing to do with speaker side or anythign appears
    I am looking on page 43 at the 'audio channel map' page on the instruction manual but i am having trouble understanding it
    chrome-extension://gphandlahdpffmccakmbngmbjnjiiahp/https://wwwapps.grassvalley.com/unsecure/DL/EDIUS_6.x/documentation/ENG/EDIUS65_Reference_Manual.pdf
    Laptop:
      WHEN i right click the audio track on the timeline and select properties, and I select STEREO instead of Mono 1... it is still mono?????
      def not stereo
      I've also been looking at this 'audio mapping' pdf but still struggling to understand what is what
      chrome-extension://gphandlahdpffmccakmbngmbjnjiiahp/http://www.ediushd.com.ar/how_to_manipulate_audio_.pdf
      Laptop:
        Copying one track just gives you two of the same track. Easiest solution is to replace the audio on the timeline. Double click the clip to load it into the source viewer and then overwrite it back to the timeline.
          Can you not go back to an earlier version of your project? Edius Projects->Your project name->Project. Try backup & autosave folders. As long as the missing media has not been taken off pc it should work.
          Sys1: Gigabyte Z370 HD3 i7 8086K(4.3Ghz), 16Gb ram, 256Gb SSD system + 2x2Tb Graphics: nVidia 1060, (W10 Pro) BM IP4K, E8v3 WG; Vegas Pro19; Davinci Resolve18_Studio, GH2(hacked), Pana HC-X2000E, GoPro5
          Sys2 :Clevo i7 6700K 2.5Ghz,16Gb ram 2565Gb SSD + 1Tb, (W10 Pro), Software: E8v3 WG; Vegas Pro19,Davinci Resolve18_Studio
            Bern I actually tried that and it still gave me 2 left tracks which was confusing!
            and Geoff no, because I don't know at what point the mistake was made, and I was continually editing the wedding highlight :(
            Laptop:
              I usually place stereo tracks on a single track instead of A1 and A2
              add the audio mode switch to the mode bar
                If the file loads into the viewer and shows 2 tracks of audio it has to be able to overwrite back to the timeline. You do have to make sure your audio patches are on and on the correct tracks in the timeline header. If you have changed the clip properties from stereo to mono you may have caused a problem. I have done this lots of times myself. I know it works, but since I am not seeing your system, source files, settings, etc., I can't tell you exactly what you are not doing to get it to work. All I can say is if the file is right and the settings are right it works, and not just in edius. It works in every NLE I have ever used, and I have used about 90% of what is on the market.
                  Check the audio mapping for tracks both in project settings and sequence settings, check also the pan on each klip
                  JoiCam´s
                  And more
                    This most likely is a panning issue.
                    Depending on your setting in usersettings ->Application ->
                    EDIUS can do 2 different things
                    1 When you copy a clip to another track the pan setting of the clip is carried to the copy on the new track.
                    2 If reset pan setting is selected EDIUS resets the pan of the clip.
                    You can see where the pan is by enabling the pan on the track or open the audio mixer and set the bus to clip.
