How to move between clips
  • How to move between clips
    Hey there-
    I'm familiar with using the A and S keys to move between clips in a sequence. I'm wondering though how I can move between clips on a single track... and not have to visit all the clips from the other tracks that are in-between. I'm sure this must be possible but haven't figured it out. Thanks for your help?
    Mobile setup: Edius X - Laptop running i7-10875H CPU @ 2.30GHz 2.30 GHz (8 cores/16 threads) with 64GB RAM and NVIDIA GeForce RTX 2080 Super with Max-Q Design w/8GB VRAM.
    Desktop: Edius X - AMD 5950x installed in Asus ProArt Creator B550. 64GB Ram and a cheap GPU w/1GB VRAM until I can get my hands on a 3080. Running Windows 10 Pro
    Originally posted by tosok View Post
    Hey there-
    Place the Timelinecursor at the beginning of the next wanted clip.
    // But i feel I do'nt understand exact what you are awaiting from Edius.
    kurt
    Intel core i7-6700K / ASUS Z170A / 32 GB RAM / Intel HD Graphics 530 / SSD Systemdrive / Gigabyte GeForce GT 1070 / Win-10/64 Pro / EdiusX-WG (10.20)/ Mercalli (V2, V4 and V5 Plugin/64bit) / Resolve-17.3.00014 Studio / ImgBurn / PowerDVD etc.
    // Read > Test > Understand
      The S key takes me to the next clip or transition in the sequence. I would like to get to the next clip on a selected track with a shortcut rather than moving from clip to clip on all tracks in the sequence, which is what the A and S key shortcuts do.
        Somewhat. You can highlight the track and go into Trim mode (F6) and then use the Page Up or Down to move to cut points on the same track. It will look like it is take 2 times to type it to get it to move, but it is changing the edit point highlight to before or after the cut (end of clip or beginning of the next clip).
