Frame size reduction for Neat video- 4k in HD timeline
  • Frame size reduction for Neat video- 4k in HD timeline
    I am using 4k footage in a 1080p timeline. Neat video is seeing the full 4k frame size. In a Neat forum they talk about having your editor send a reduced frame to Neat to work on.
    Does anyone do this or know how to?
    Thanks,
    Alfred
    do a Shift-Q render (render and add to timeline) and put the neat video plugin on the rendered file. The render makes a file at the timeline resolution, not the source file resolution.
    Edius WG 9.55.7761, various 3rd party plugins, VisTitle 2.9.6.0, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX680 4GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX680 and one on Intel HD4600).
    • BernH
      BernH commented
      Editing a comment
      I missed the f in shift and got **** in place of the word.
    If you put neat video before the layouter it will work on the 4K original. Another alternative would be to nest the 4K clip in a sequence and then applied Neat Video to the sequence.
      Neat VIdeo needs to be applied before the layouter.
        I have Neat before the layouter. I am shooting concert video with 2 or 3 4k cameras. I may produce 10 or more multi-cam song clips So far I have found the Q shift problematic, but I don't remember what the issue is.. After syncing the cameras, I put each camera in a sequence and apply color correction (and recently Neat). I then nest these cam sequences to do my multi-cam edits. So would I color correct a cam sequence and then nest it and then apply Neat to that sequence and put the resulting sequence in my multi-cam sequence?
        I am trying to do as much nesting as I can, so that I can go back to an earlier sequence to adjust fx, color, neat etc. rather than dealing with all the bits and pieces in my final edit.
        Thanks for your response.
