Burn to BD ? volume label and work folder
  • Burn to BD ? volume label and work folder
    Any help appreciated. Can't find answer to my "burn to BD" questions in the manual.or by searching forum.
    For the first time, I am trying to burn a project onto blu-ray (client requested one). I'm burning at different format settings trying to get the perfect BR burn. So I burned one at 1440 1080 59.94i. (my actual E.9 project setting)
    Next, I tried to burn a BD at 1920 x 59.94i.
    Under "basic" /output tab/ settings there is a "volume label". What is this? When I try to put "0-9 or A-Z" in that spot it doesn't like it. So i don't. But when i go ahead and hit "create disc" I get the following messages
    "The folder contents already exist. Would you like to delete contents?" So I hit yes.
    Another window comes up "The work folder already exists. Please check if any files in the work folder are being used."
    So....I powered the computer down and back up. Now i could burn to disc with this new 1920 x 59.94i setting.
    So my questions are....where is this temporary "work folder"? And why can't I put anything in this "volume label" box?
    Thanks!!!!
    Lori
    Edius 9.3, ProASUS TUF X299 Mark I LGA2066 DDR4 M.2 USB 3.1 Dual LAN X299 ATX Motherboard, Intell Core i7-7820 X Skylake-X 8-Core 3.6 GHz processor, GTX 1070, 500 GB Samsung 850 EVO SSD), 4TB WD Enterprise HD, 16 GB Ram, 2 LG DVD burners, Win10 Pro. Intensity Shuttle. Vitascene V.3. Vistitle 2.8 +
    the Volume label is upper case and short, you can call it BD or VIDEO etc.
    you need to enable detailed settings and specify the path to the work folder, the default is the Win Temp folder, I never use the default.
    I set it to the EDIUS Project folder so I can burn further Blu-ray at a later stage from that folder without any re-encoding
    https://www.videoproductions.com.au/...VDburner08.png (screenshot is from an older EDIUS version but basically the same)
      Got it!! Thanks Anton
