voiceover not working in ediusx 10.20.7620
  • voiceover not working in ediusx 10.20.7620
    Hi
    starting with the latest version of edius pro x (10.20.7620) the voiceover that was working well with the previous version doesn't work anymore.
    The countdown reaches number 2 and then it stops.
    The same issue appears in every edius project.
    I tried reinstalling audio driver with no results.
    I also tried reinstalling ediusx (same version).
    Anyone has the same problem?
    Any idea?
    Thanks in advance for your help
    Marco
    Last edited by GrassValley_SL; 07-14-2021, 03:36 PM. Reason: Adjusted font color to automatic
    Hi Marco, I just tested this and it is working. Do you have the capability to do a video screen capture?
    If so, please make one so that we can watch your process.
    Do you have the Voice Over Device selected on the Voice Over pop up panel?
    Are you seeing meter deflection from your audio source.
    Also, part of your text in your original post is white and the turns black.
    You might want to correct that.
      Are you adding the Vo to the bin or the timeline?
      If timeline clear in and out pont wit the X key.
      Can you also try adding the VO to the bin instead of the timeline?
      I tested with my onboard mic (NOTE BOOK) and an external mic trough a umc204hd . Both times I have been successful in recording the VO.
        Works correctly here. Mark in and out on the timeline where I want the VO, select the VO feature, make sure to select the correct device preset and hit start.
        My System: Edius Workgroup 9.51 & 10.0, Intel I9-9900K 3.60GHz Liquid Cooling, MSI Z390-A PRO MB, 32-GB Mem, GeForce GTX 1660 6GB GPU, BM Intensity Pro 4K Card, Win 10 Pro
          Works fine here also. But I suspect we all have WG, not Pro. Have you tried to recreate a Device Preset?
            With the new device preset also create a new user profile.
              Thanks all for help! I will try your suggestions and I will came back here with the results.
              Marco
                Hi
                creating a new preset and a new user profile fixed the voiceover problem.
                thanks a lot for your help
                marco
