9.55.7303 WG upgrade with some issues
  • 9.55.7303 WG upgrade with some issues
    Hi,
    after upgrade to 9.55.7303 WG version I have come across to two issues
    1. Main windows of Edius (sometimes) is still above of other programs windows (I can not switch to other programs).
    2. Mync is really slow! I have to wait minutes for importing files.
    Do you have the same problem?
    In the end I have had to install older version.
    Thank you.
    EDIUS Pro 9.50.5351 WG, Intel Core i7-8700K 3.7 GHz, 32GB RAM, Nvidia GeForce GTX-1080Ti, Win10 Pro, Blackmagic DeckLink 4K Extrema 12G
    Sony PXW-FS7, DJI Phantom 4 Pro
    no issue here
    before installing any update, be sure to empty appdata/local/Temp
    make sure faststart is disabled in power options
    restart PC
    disable any third party antivirus
    install EDIUS
    re-enable your anti virus
    if using Windows Defender only, there is no need to disable
      Wow is it something new?
      I never need that. I have been upgrading since version 3 without any problem...
      Thank you I will try it.
        the EDIUS installation instructions say to disable the antivirus while installing
        emptying the Temp folder is something that is done on a daily basis by the PC user, this avoids file conflicts especially when installing
