editing GO Pro 9 with edius 9
  • editing GO Pro 9 with edius 9
    Hi all,
    I tried to edit go pro 9 project at 4k 60p
    My buffer is only 1/258 which is making my timeline audio and video jumpy .
    i have tried adjusting my project settings from 10bit to 8bit as well.
    nothing works
    i have edited nikon d850 uncompressed 4k at 30p without any problems
    what are the best settings or is their a work around?
    cheers
    4k 60p needs a serious PC if file format is h265 or similar
    convert in bin to HQX and you will have realtime
      Thanks Anton,
      Do i use the main HQX file?
        Originally posted by speco View Post
        Hi all,
        nothing works
        cheers
        thanks Anton that worked
          Thanks Anton,
          yes, HQX should be realtime even on slow PCs
            Up to now, EDIUS9.55、10.20 does not support the decoding of h264 and h265 by independent graphics card, so its performance is very poor(Especially the decoding of DJI and go pro). I hope edius10.30 can support decoding.Can only wait, hope is dim.
