Edius X 10.20 Won't export
  • Edius X 10.20 Won't export
    I am trying to export a 4 minute video I revised today. I exported it on Friday with no problem. I check the status in the GV job monitor and it will not start export. I cancel all jobs except for the one I want and nothing. I restarted my computer, copied the sequence to another sequence and still no export. I tried to export a different file and still no export. What may I be doing wrong? I have never had this issue before. Thanks in advance.
    I opened up the same project in Edius 9 and was able to export. Seems like there may be a bug with the GV job monitor?
      Was there any kind of error message? Can you export other items from EDIUS or does GV Job monitor not start at all?
        GV Job Monitor does not start at all.
          Are all (Windows) EH... services started?? // I have set them all to "Automatic" (without delayed)
          kurt
          SW: WIN-10/64 PRO (21H2-19044.2006), Firefox u.a.
          NLE: EDIUS-X(10.33.9356)-WG; RESOLVE-18.0.4.0005 Studio​​
          // Read > Test > Understand
            close the job mon
            instead, tick add to bin in export window, then the clip will show in the bin with a progress bar, does the progress start?
              I managed to have the same problems with Edius X ver 2030 and eventually worked out what the problem was after an hour of tests, it was the name of the sequence. I named one of my sequences Bride / Groom. Keep the name short and do not use / and you should be good to export. Hope this helps someone.
                While not specific to Edius, here is a link to a fairly comprehensive list posted by a shared storage manufacturer of characters you should avoid https://support.promax.com/en/knowle...ial-characters
                Edius WG 9.55.7761, various 3rd party plugins, VisTitle 2.9.6.0, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX680 4GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX680 and one on Intel HD4600).
