Export problem after update to Edius 10.20
  • Export problem after update to Edius 10.20
    Hi,
    today I made an update to 10.20 and my export no longer works !!! In the project in which export worked yesterday, today, after the update, it no longer works! The same export to the job monitor stands at 0% and goes no further!
    I can't export anything ... mp4, avi, wave ...
    Please help!
    Thank you,
    Tomislav
    Here is Edius system report...
      ...after reinstallation, problem persist...
        uninstall EDIUS and do not deactivate
        reboot PC
        empty appdata/local/Temp
        install 10.20
        reboot and it will then work
        make sure faststart is disabled in power options
          I uninstalled Edius, rebooted PC, emptied appdata / local / Temp (except: edius_net_setup_manager_tmp - I can't delete), reinstalled 10.20, disabled fastsart
          AND THE EXPORT DOESN'T WORK AGAIN ... PLEASE HELP!
            Do you have enough drive space on the destination drive? Try a different destination drive and see if it works.
              I went back to version 10.10 and now everything works again! There is something wrong with version 10.20, at least on my PC. When uninstalling version 10.20 EVERY TIME my PC froze when it uninstalled the "GV video I / O hardware driver". When reinstalling 10.10, when he installed the "GV video I / O hardware driver" it took too long but it passed (thank god).
                Not exactly the same but on my PC Job Monitor hangs with the indication of (Connecting) in the lower right corner and nothing nothing appeared in there when I export from the timeline.
                uninstall, reboot and install uninstall three times along with emptying the appdata local temp folder but it stays the same
                JoiCam´s
                And more
                  you need to disable faststart before rebooting after uninstalling EDIUS, and never re-enable faststart, it is a Microsoft disaster invention
                  also uninstall the EDIUS setup manager, you don't need it
                    Thanks a lot Anton,
                    I did everything as you said, but it still doesn't work. I will wait for the new version and then try again.
                    10.10 works great!
                      Thanks a lot Anton,
                      10.10 works great!
                      can you tell me which antivirus and antimalware programs you have installed? something must be blocking something
                      also, in EDIUS help menu, generate a system report and attach it here
                        I only have default windows security with added exceptions (folders: c-program files-grass valley, c-programdata-grass valley and c-users-tom-appdata-roaming-grass valley).
                        I have already sent the system report (post # 2).
                        Yes, it is clear to me that something is blocking something but I can't find what!
                          the system report in your post 2 is corrupt, I can't view it, see attached
                          maybe send it via antonsvideo.wetransfer.com
                            Now I have re-installed 10.20 to make a new SystemReport, and now Export WORKS !!!
                            The only new thing I did today was uninstall the EDIUS setup manager. I do not understand...
                            Anton, thank you so much for your help!
                              I'm having this same issue as well.
                              Have tried all the steps mentioned above multiple times. Have tried re-installing older version of 10 and nothing is working.
                              I don't have any anti-virus installed other than windows default security as well. Everything was working fine a few days ago....outside of installing Discord, nothing has changed system-wise to my knowledge.
                              I've attached a systems report.
                              Any help is appreciated.
