Best way to upload XDCAM files to Edius
  • Best way to upload XDCAM files to Edius
    I would appreciate recommendations for the most efficient way to upload XDCAM files to my computer to use in Edius. These files are about 1 hour in length. Sony Catalyst Browse and Edius Source Browser are the two options I am looking at.
    JimG
    System 1: Windows 7 Pro SP1, EditHD UltimaX 620Z, Edius 6.54, Vistitle 2.50, 3.8 GB Xenon Quad Core, 16GB RAM, Nvidia Quadro 4000, HD Spark, Intensity Pro, 240GB SSD System Drive, 3- 2TB Media Drives
    System 2: Windows XP SP3, Edius 5.51 Vistitle 1.8.7, P5W DH Deluxe, Core 2 Duo E6750, 2 GB RAM, EVGA GTX 460, 250 GB SATA, 500 GB RAID 0, 2-1 TB Media
    EDIUS Source Browser is the way to go
    select XDCAM and you will see the clips under it in a folder
    select all clips (Ctrl+A), then right click and choose add and transfer to bin, all
    WARNING: You must set your user settings as seen in attached otherwise the transfer will take light years
    https://www.videoproductions.com.au/...settings-2.png
      Thanks for the tip!
      JimG
