Alt + Right clik mouse
  • Alt + Right clik mouse
    Hello EdiUsers
    I like these function.... Easy to move the time line left or right.
    I would like to have it without the need of Alt + So I mean only right clik on the time line and move.
    I can attributes function combinations with the keyboard but not with the mouse.
    Thanks for help
    Main System: Azus Z87 Pro, [email protected], 16gb ram, Nvidia GeForce GT 630, Windows 7 Pro 64, Samsung 840 pro, Edius 8.53.2808 WG and 9.54.6706 + NXexpress or HDspark, 2T separate video SSD.
    Haddock...thanks so much.
    For thirteen years now I had been wondering how I could slide the timeline left and right with the mouse.
    Now I can! So happy.
    I almost always use CTRL+Scroll Wheel on the mouse to zoom in and out of the time line but I had to use the scroll bar at the bottom of the timeline which is slow and inexact.
    Your teaching today on how to move the timeline left and right using Alt+Right Click is a game changer.
    Merci!!
    PS: I dunno how to set it up so you don't have use Alt+. Sorry.
    Cory Bretz
    Heirloom Films and Storybooks
    www.heirloomfilms.ca
    Life Stories & Family History
    MSI GT75 Laptop with i7-8750H 2.2GHz Hexa 6 Core processor, 48GB Ram, 256GB SSD + 2 TB NVME, GeForce® GTX 1080 8GB GDDR5X & 2 LG IPS235 monitors, Thunderbolt™ 3 & 6TB G-Drive, Edius Pro 10, NewBlueFX Titler Pro 7, VisTitle 2.6, Windows 10 Home Ver 1909 and an army of tiny video editing faeries.
      I have requested an alternative custom option for this almost 20 years ago
      I know of no way other than Alt+Right Click and drag
      in Speed Razor it is as simple as right click and drag (very old software)
        20 years ago... Amazing... a so usefull function.... Well it seems that we are a few to ask it...
        Anyway I made a happy man member since 2007 : Cory. I apreciate his : Haddock...thanks so much.
        • spurfilm
          spurfilm commented
          Editing a comment
          20 years ago sometimes feels like yesterday.
        I don't know if it works with all mice, but by using my Logitech mouse scroll wheel and tilting it left or right will move the timeline. left or right. No need to use the Alt key or right click, unless I have misunderstood what you want to do?
          I have tried this some time ago but it only works well if you are zoomed out a lot, it works terrible when viewing say 5 frame scale
          Also, often when tilting mouse wheel right or left, playback will stop because if you accidentally move the scroll wheel forward or backward while tilting, play stops, and that is easily done
          so my preferred settings for tilt is zoom timeline
          left tilt - Ctrl+5 for 5 frame viewing mode
          right tilt = numeric keyboard - for zooming out one step at a time with each tilt (or alternatively Ctrl+0 to show the whole timeline)
            Fantastic... I have try the logitech mouse... and it works well. I will now practize and see
            Thanks John and Anton for these info.
              Hi all. These tips are really terrific, and thanks for sharing. I do have one caveat I would like to post. Using all of my computers (EDIUS editor included) quite a a bit, I began to develop a modicum of Carpal Tunnel Syndrome using the "flat" Microsoft type mouse. A learned computer gamer suggested I look into the EVOLUENT vertical mouse, which does not promote the twisting of the arm and thereby relieving Carpet Tunnel. Now I use the EVOLUENT on every computer, and it has relieved my symptoms for sure. No tilting of the mouse wheel like the Logitech, but several buttons on the EVOLUENT can be easily programmed with the included software.Take a look - https://evoluent.com/products/vm4rw/.
              Best to all, Alan
              Alan J. Levi
              Director
