Quick titler has stopped working on edius 8.53 -how to fix it ?
are you using Win7?
have you rebooted since the crash?Anton Strauss
Is it not starting, or starting and crashing?1: 3970X Threadripper, Asus ROG Strix TR40 E Gaming, G. Skill Trident Z Neo 128G DDR4 3600, EVGA GeForce RTX 2080Ti, Samsung 970 EVO M.2 1T, Intel 660P M.2 2T (2), Seagate Ironwolf NAS 12T, Enermax TR4 360 AIO, Lian Li 011 DXL, AJA Kona 4, Asus ROG Thor 1200
Can please you try a new user profile?
Go to system settings->application-> profile and create a new user profile.
After you have created the new user profile exit the system settings.
Go to the settings drop down and then choose change user profile.
Select the profile you have just created and then save the project.
Exit EDIUS
Start EDIUS is the issue solved?
