Hi everyone, I use a USB hdd to storage my Edius project files and media files, I open it and edit using 2 PC's, every PC has same fonts installed. But every PC shows and displays all titles different way, for example:when I create a title using PC 1 (and quick titler) centered horizontally - a second PC shows that title not centered, in different possition, same project, same fonts installed, same Edius version, different titles possition. Why?
Titles possition issue.
Do both systems have the same size monitors? For example, 1920x1080? Also, In Windows 10 Settings > Display > Scale and Layout are both systems set at 100% scaling?Jerry
More resolution and scaling.Jerry
Edius is a software that has so many stupid issues.... its like photoshop, indesign or Corel Draw generate text objects depending on monitor resolution etc... who creates it? Another stupid issue is changing sequence name, try to change in bin window and on sequences tabs it wont change but if you change sequence name double clicking on sequence tab - it changes sequence name in clip bin....
it would be handy for many if save as etl2 could be set as save defaultAnton Strauss
Got curious as I'm doing some titles. When I do a "save as", there is a "Save as type" dialog box. Choose the "Quick Titler File (*etl2) " option from the drop down menu triangle. The next, and every time thereafter, when I "auto save as" the title will keep being saved as an etl2. So it's kind of automatic after I first "save as", changed the file type, and then use "auto save as" from each subsequent title.
Main - Edius Pro 9.55, Windows Pro 10 20H2, Lenovo Ideacentre 720-18APR, AMD Ryzen 7 2000 8 core 3.2 GHz, Radeon Rx560 4096 MB.
Dub - Edius Pro 9.55, IMac Windows 7 bootcamp, Sony MVMC-DA2 DV converter, Sony BVU 800, Sony BVW, Sony DCR-PC101, Sony GV-D800, Alesis MultiMix 8.
Old Cam - Panasonic HVX200 (DV100_1080/59.94i), AJ-PCD-10, P2 F series cards.
