I'm trying to convert some old Hi8mm analog tapes to digital. I recently bought a (cheap) video capture device (StarTech USB video capture cable -- I know it's low end, but that's not the issue).
I installed the drives for it, and set up a device preset in Edius 7.5, and it seemed to work great at capturing the video on a few test captures (notice past tense). It also worked capturing the video using the (low end) video editing software that came with the cable unit (Movavi).
Well, I was fooling around trying to get the S-Video input to work (all the tests were done using the RCA video input), and somehow the Edius capture no longer works. I uninstalled/re-installed the drivers for the unit; that didn't help. I set up a new device preset, using the settings from the first time when it was working (because I had taken a picture with my phone of the settings) but still nothing.
The odd thing is that it still captures just fine with that Movavi editing software. I don't get any errors when I select the preset. If I disable the device in Device Manager, then the preset doesn't even load. The video stream and the audio stream are set identically between the Edius preset and that Movavi software. I know the camera is outputting because when I connect it to a TV it outputs, and as I said, it is outputting through the cable unit in that Movavi software.
And it worked once (actually a few times) in Edius!
Any ideas what the heck I did to make it so that Edius doesn't "see" it properly anymore?
