Problem with Newblue tilter Pro ?? Help
  • Problem with Newblue tilter Pro ?? Help
    Dear all ,
    after creating my texts and effects in Newblue tilter Pro which comes with edius X , and adding the text to
    edius timeline i got the following
    see the attached photo please
    help me
    it waS WORKING WELL BUT I DO NOT KNOW WHAT HAPPENED
    i HAVE FORMATED MY PC AND INSTALL EVERYTHING AGAIN AND THE PROBLEM
    STILL THE SAME
    This looks as if Edius has lost contact with the drive on which the TP7 for Edius X files are stored. Can you restore the file or was the file
    corrupt? Do you see the .nbtitle file stored within the Titler Pro folder in your project folder?
      yes this file is stored in the project file and I found if i delete it everything works fine , \but it is a problem if i need to delete every time
      how to solve it
        Is it stored in the titler pro folder within the project folder?
        Does it disappear each time or with different titles?
        Can you do a video screen capture to show how this happens?
          Yes it stored in the titler pro folder within the project folder
          when i delete the nbtitle file eveything works fine
            Are the cache files also showing in the TItler Pro folder? The next time it loses connectivity, try to re-link the title.
              after I delete the nbtitle everything works fine but if i cloesed the edius x and open again
              the titles again are missing like what i saw you ,
              see what i get in the project file
                Do you have any other NB products installed in Edius X? If not, uninstall TP7 for Edius X and clean out all of the New Blue folders.
                After that, reboot. Re-install TP7 for Edius X and then reboot again.
                Now open Edius X and see if it works.
                  Only i have the newblue ofx bridge 2 that comes with edis x package itself
                    Nothing changed I have tried all things u said in your last reply but the same result . I don not know what happened ? The only thing i did is formated my pc as normal but this is the only time i face this program since i started using Newblue titler pro .
                      Also had the same issue happen to me, was actually wondering what the issue was
                      EDIUS 9.5 /Win 10 x64 Dell T5600 INTEL Xeon 16 core @2.66GHz 32GB RAM /NVIDIA GEFORCE GTX 1660TI, SSD SAMSUNG 500GB PRIMARY, WD 5.5TB STORAGE, 2x WD500GB ASSETS, heroglyph 4.0, Sony AVCHD cam, Canon DSLRs.
                      Sys 2: Asus ROG G75series
                        If you delete the title from the timeline, then save and exit EDIUS, then there is no way the title will come back when you restart EDIUS
                          Did not u find a solution yet ?
                            I DID NOT DELETE THE title from edius , this the file that is stored in the project file
                              view the properties of the clip to see the path of the offline clip, then check if it exists
