Issues with Vistitle 2.9 in Edius X
    Hi Anton
    In E9 it is VtEDIUSImporter "7" and in E10 it is VtEDIUSImporter "X"
    DVC Built for AVID MC (Now + EDIUS Workgroup 8.5.3)- Giabyte GA-X58A-UD3R, 2.66Ghz Intel i7-920 Quad Core HyperThreading processor, 1 NVidia Quadro FX1800 768MB, Win W7 Pro 64 bit, Now Win 10 MC Ver 8.4.4.3850, Workgroup 8 (8.5.3.3262)
    DVC Built for EDIUS- Giabyte GA-Z170X-Gaming 3, Intel i7 6700K, Skylake Quad Core 4.0GHz, 32GB Ram, 240GB SanDisk, Win 10 Pro 64 bit, Blackmagic Intensity Pro 4K, EDIUS Workgroup 8 (8.5.3.3262) Plus 9 (9.51.5619) VisTitle 2.580 Just a Hobby.
      that is correct, so if E9 starts correct, then it is an issue with EX or with Vistilte implementation
        As I mentioned earlier it is only this one project that won’t open in E10. Other projects, with not that many Vistitle files open OK. In E9 because his is a large project, I may get flash screen not responding create a system report. I ignore that because with E9 it will open shortly after.
          Hi
          Something strange just happened. I opened the project in E10 and the System Report Window popped up and I just left it and I would suggest about 15 minute later the project opened in E10.
          Obviously, I have tried that before and left it for hours without any luck. Now I have just tried again and at 17 minutes it opened again.
          My observation with E9, is that it opens, I’ll say ok, but when open if I try to scroll up and down the list of Vistitle lower thirds using the up and down keys it stalls and the spinning wheel appears. After a while it catches up and jumps to the last key position. I can only assume the files are being rendered and that may be why E10 will not open?
          In E10 I can scroll up and down straight away!
            Is the project on an HDD, SSD, NVME, or external USB? Are all of the assets within the Project Folder or spread around the system on different drives?
            • #21
              The project is on an HDD the VisTitle files are on a WD USB the media is on a different HDD and three external WD USB’s
