More than 5000 files play hide and seek with me!
Ediusx has been castrated with AE bridging function. I have more than 5000 files on a time line. How can I find out where the looks plug-in hasn't been removed? I'm going crazy. Cancel“ ✔” It doesn't work. You have to delete the bridge effect in the message window. You have to delete it, else it will not be output, only an error will be reported. it won't tell you which material the undeleted plug-in is on.
At the same time, when recovering offline material, the pop-up recovery window is very slow,The software stopped responding for a minute or two.123.jpg
以下是详细信息:
[2021/3/15 20:46] Registration
[2021/3/15 20:48]
Failure :
找不到指定的对象。
- Effect - Canopus Co., Ltd. AffterEffects Video Filter - MB LookSuite3
以下是详细信息:
[2021/3/15 20:48]
Failure :
找不到指定的对象。
