EDIUS NX and COMPONENTS SD OUTPUT
  • EDIUS NX and COMPONENTS SD OUTPUT
    Hello.
    A customer of mine has trouble outputting SD video to a monitor via COMPONENTS output of NX card.
    If editing an HD project, Components HD output works.
    But when editing SD projects, only NX S-video and composite works, and Components SD does not works.
    Any suggestion ?
    have you set the output to Multi-Format? instead of HD or SD exclusively
    I always leave mine on Multi-Format, then component is available under SD and HD
    General I/O settings under hardware settings
      Of course, I hope they know that an SD output on a HD monitor will not look good. I have HD going out the componet to an HD monitor and the SD going out composite to an SD monitor.
        That's not true. My Panasonic LH1700W does both HD and SD beautifully. Much better than a normal SD TV.
          same here, SD and HD component look great on my 42" Fujitsu HD Plasma
          no scaling artifacts whatsoever
            I assumed you were talking about pro monitors
              Tahnk you to all.
              Problem solved. the problem was that the DELL monitor is not compatible with SD signals via COMPONENTS. Tested with a projector via COMPONENT and all works fine.
