I'm having an issue where if I try and slide a logo left to right that is not full screen on it appears to start showing up about maybe 1/10th into the video. Almost as if it's masked. I'm using workgroup 9 and I remember finding a setting in 7 that fixed this. Can anyone help me? Thank You.
Transition fx settings
That sound like it might be the overscan setting in the project settings. Set it to 0%Edius WG 9.55.9157, various 3rd party plugins, VisTitle 2.9.6.0, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX680 4GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX680 and one on Intel HD4600).
Yes, go to your project settings and set the overscan setting to 0. Why we still have that analog setting of 3% is beyond me. Steve and I have jumped up and down to try and get that default setting changed (as well as several others).1: 3970X Threadripper, Asus ROG Strix TR40 E Gaming, G. Skill Trident Z Neo 128G DDR4 3600, EVGA GeForce RTX 2080Ti, Samsung 970 EVO M.2 1T, Intel 660P M.2 2T (2), Seagate Ironwolf NAS 12T, Enermax TR4 360 AIO, Lian Li 011 DXL, AJA Kona 4, Asus ROG Thor 1200
Originally posted by MWSimon View PostBernH!! Thank You. I know I had found that setting several versions back and for some reason I could not remember for the life of me where I set it. Have a great day!Edius WG 9.55.9157, various 3rd party plugins, VisTitle 2.9.6.0, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX680 4GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX680 and one on Intel HD4600).
If you use the Project Preset Wizard to create your projects in bulk, it allows you to select the tickbox to set the overscan to 0% (look at the screen shot).
Otherwise, the setting is manual.Attached FilesJerry
