Where are the engineers? Rewind is much smoother than playback!
  • Where are the engineers? Rewind is much smoother than playback!
    More than ten times performance improvement!A very interesting discovery,
    -3X playback dropped frames VS 3X Show all frames! Clip video upside down ,The output also reverses,I found a way to significantly improve the performance of EDIUS!
    https://www.skypixel.com/videos/ediu...d-21c5f34dba62
    This Video is Dji Mavic2 Pro,4K 265 10bit 420,Other materials(265 264 Braw R3D MXF) are the same result!
    Now hevc coding is more and more popular, I hope EDIUS will not fall behind.
    Intel QSV technology can significantly accelerate h265 preview performancem,GPU is HD630,Well, I mean Video speed change is very important for aerial photography,I set 700% speed
    (Shortcut key: alt+e),playback will not be fluent,
    then Press "L" 3 times to play 3x speed,of course It's not fluent.but Press "J" 3 times to play speed -3x,The video preview is very fluent.so I feel very strange,It's so fluent that it doesn't need rendering at all.
    If using AMD ryzen or Intel Xeon Processor,H265 Speed up playback(more than 300%),playback will not be fluent,Hope to improve the decoder, provide an option to achieve a certain frame loss, so that the video looks fluent.be similar to DaVinci、Premiere.
    Video download address:https://cloud.189.cn/t/3MnEfqER732y and https://drive.google.com/drive/folders/1qXL4SjOV-Svp1cDriMzAI7HbpidJPkfA?usp=sharing[/url]
    CPU:AMD R9 5950X GPU:GTX1050 MEM: Micron 4G DDR4 2400x4
    motherboard:ASrock X570 matx
    SSD:intel p3600 sata HDD: HGST 8Tx5 raid0
    Power:Great Wall EPS2000BL 2000W
    OS WIN10 20H2
    Is there a way to provide some of your file?
    Honestly I am confused in what you are trying to show. Yes it seems strange it will not play forward but will play backward. The language barrier makes it a little tough to try and duplicate. I do not have Quicksync on my machine. But I use a H.265 file and it plays with no problem so it is hard for me to duplicate anything you are trying to show. Also showing the graph when playing forward and the percentages when playing backward makes it hard to see what you are trying to show.
    I find your playing method strange when using the speed slide bar under the monitor. I am not sure why you are using that. To get the cursor to play right to left you have to be using the J key. Every time you type J it will increase/decrease the speed, so no need to use the bar. I would like more information.
    • 363596694@qq.com
      [email protected] commented
      Editing a comment
    have you tried lowering the preview resolution to 1/2?
    • 363596694@qq.com
      Editing a comment
      This method does not work for h265,I feel so said
