Can anyone explain after I render an entire 1.5 hour timeline and then make a change without effecting the length I have to render all over again? The change is a letter change from TMP.
Thanks,
Ara
Thanks,
Ara
The reason for rendering the entire timeline is due to the fact of many many filters, slo mo and so on. This is usually done just before the conversion to DVD. Could you explain why I have to re render areas after this change I make? Could it be render settings?
Thanks,
Ara
Does the entire timeline color change or just the change area? If it is this,
put in and out points and then render within those points.
Six Gill DV www.sgdvtutorials.com If you own the Tutorials and you need help, PM me.
I make in at beginning and out at the end and do a complete render of all areas. When completed the entire timeline is green. When I make any change like a title at the beginning than the entire timeline looses that green color and becomes different colors again like there was no render at all.
Thanks,
Ara
I don't have that issue. If I make changes the only color change is on the area that has been modified. I then have the in and out points and re render.
But if the time line is converted to dvd it makes no sense to render it at all .
Just export it to file you use and that export will take care of everything.
The only reason you would ever render the timeline is if you are playing realtime to a dvd recorder.
Steve EDIUS Trainer, Grass Cutter Gold
Ah...ok know I get it. I thought you where exporting to a file for burn.
If you do a RENDER between IN and OUT prior to output then make a single change then you WILL have to render the whole lot again - I think when you render an entire area EDIUS makes a TEMP file corresponding to the rendered area I think its an info file for the system........So any changes will effect the whole TEMP file THUS a rerender is needed.
I only render parts that are not RT and 99% of my work is realtime - Far less hassle to encode to Mpeg 2 and do a quick DVD author?
Multiple layer sections with lots of filters effects is what I have to render But they are done in sections IN and OUT points.
Can you work this way?
