Multi CAM
  • Multi CAM
    Is there a way to reverse multicam cutted clips back to original?
    I want to recapture multicam footages from the original footages on the timeline.
    Can you explain a bit more clearly what you want to do?
    If you used multicam view to cut clips, this doesn't do anything to the original clips except put cuts in them and a note to change from tack 1 to 2 etc.
    If you made a final movie and intend to put this on your timeline, then you can't split it back up again to the original.
    www.myvideoproblems.com
      Yes!
      While in Multi-cam mode, Double-click the dinky triangles above the cut marks to delete!
      To preserve the original cuts you can opt to "enable" cut clips by selecting the clip and pressing "0" (zero)
        Thanks for reply, I will give it a try...
          Hi, I am new in this forum and I just started using Edius 5. Where can I find instructions on how to edit multi cams, I need the very basic instructions. Thanks
            You can download the "Help" file "pdf" from the GV support site once you have registered and logged in
            After downloading the file rename it to "Edius.pdf" and copy to C:/Program Files/Canopus/EDIUS 5 directory and then when you hit the "F1" help key it will come up.
            Search on multicam, it is rather rudimentary but may give you a clue to perhaps ask some more questions for clarification
            Best way is to try yourself and make a mess on the first one it sinks in faster, well it does for me. Remember that what ever the mess the original files are intact so you can try again, I think you will find it quite easy after a couple of goes.
            Print out the relevant pages and keep close
            When you copy the "pdf" file there may be one already there, when it prompts to overwrite click OK
            As you will find out there are MANY ways of doing it so have a go first
            Regards Barry
              You Tube
              Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.
              its for ver 4.6 but you will get the idea.
              Once you figure it out - multicam editing in Edius makes things alot easier!
                To reverse your multicam work, you can mark an IN and OUT point on the timeline where you want to undo the muticam edit and right click on one of the blue multicam cut markers and choose "delete markers between IN and OUT".
                All the cuts will go away and the clip will be a solid clip again without cuts.
                p.s. UNDO will make all the cuts come back.
