My registered Edius 9 WG ID is not working when I launch Edius X. Any ideas whats going on?
Edius X install problem
Thanks,
Ara
Windows 10 Home 64 Bit, Edius WG 9.55.7303, Edius X WG 10.20.7490 Intel Z370X Motherboard, i7-8700K 4.7 GHz 6 core, 12 Thread LGA-1151 CPU, GTX-1080 8GB Graphics card, 500GB M.2 PCIe NVM SSD, 16 TB Raid 0 Media Drive, 32 GB DDR4 Memory, Intensity Pro 4K AV I/O, CS 5.51 Production Suite.Tags: None
Originally posted by ajcvideo View PostMy registered Edius 9 WG ID is not working when I launch Edius X. Any ideas whats going on?Anton Strauss
did you enter the EDIUS 9 Plus serial? check the license list in license manager and make sure it says Plus, only a 9 Plus serial activates 9 and XLast edited by ajcvideo; 01-29-2021, 12:36 AM.Thanks,
Ara
you deactivate the existing 9 serial and enter the Plus serial
in license list of license manager, you should then see the Plus word as part of the license
if you bought it as an upgrade, you also need to enter a previous serial when askedAnton Strauss
Originally posted by antonsvideo View Postyou deactivate the existing 9 serial and enter the Plus serial
if you bought it as an upgrade, you also need to enter a previous serial when askedAttached FilesThanks,
Ara
Update. I now see the plus in license manager. I now can open Edius X with out the trial version days. I don't know what I did but it works. Thanks again Anton.Thanks,
Ara
