EdiusX vs Premiere cc2020 rendering test
    I turn off the line colors on all my systems, they are just annoying and not needed in my opinion
    I want to try to do as you say, and let's see what changes, thanks.
    Edius pro X -W10 pro -Lumix fz 1000-I7 10700 8 core-RAM 64 gb 2666 Mhz-GTX 1660 super 6 gb-GTX 960 4 gb-DJI Ronin-SC-
      I did as you told me, see attachment, did I do it right? thanks.
        if you compare to my screenshot, you missed one item
          Excuse me but I don't understand what I did wrong? forgive me but I don't understand, maybe I have to select the item "contents that are not in the project format"? thanks
          volume_up
            make your screenshot look the same as mine, did you see mine? if not, I attach it again here
            • #21
              that's it now okay?
              • #22
                yes that is now ok
                • #23
                  ok thanks a lot. i'm sorry to ditch edius, it's a software that works well and i've always felt good, fast and works with native 4k files, apart from the slow rendering issue on ediusx, however i will get used to working without rendering every time i put a clip in timeline. thanks bye.
                  • #24
                    Originally posted by GrassValley_PS View Post
                    Quit worrying about what color the line is. Instead you should be observing the buffer.
                    What do you mean by looking at the buffer? What and how should I set the buffer? thanks.
                    volume_up
                    content_copy
                    share
                    • #25
                      set the buffer to about 2GB and 10 frames
                      then play timeline and if it climbs to its max value, you don't need to render, see attached video
                      • #26
                        ok thanks
