Bt. 2020 Edius Time Lapse Workflow Problem??
    Yes, I selected it, but it didn't have that arrow tab that your's did.
    Interestingly, however, I discovered that when I imported several stills into the bin, whether in detail view or not, if I manually, through properties, converted just the first image in the string to a different color space, I could then select all the images and convert them to a sequence and in properties, it would show that this sequence was in the new converted color space, even though the first image was the only one which had been converted from 709. Not, sure whether this is truely accurate for the whole sequence, but that's what it shows in properties for the sequence. If in fact, this is accurate, it would certainly make it easy. Perhaps you can look into this.
    Yosemite Channel - Barry Chall Films:
    https://m.youtube.com/user/Tarnway0412
      Check you bin columns,
      It works fine here.
      color space.mp4
        I don't know what the issue is, but on my raw stills from the Sony A7RII which are 7953x5320, I do not have the same options or view as shown in your video. I do not have the part on your's which says BT.709 [Full] or any pull down arrow to the right of it like you have. I do have something not displayed on your's to the immediate left of the clip # which has a white tick box which says Default Still Clip- your's says still clip with no white tick box. Also, unlike your's, I have a pull down arrow tab to set aspect ratio, which is not present on your's. Mine also has headings for start and end times, and a column for reel No. It would seem, we have two very different things happening in Detail View. Not sure how to get the view/options you have.
        I'd like to be able to attach a screen shot, but not don't know how to do that on this forum page.
          You need to add color space to the bin detail view. You can select what is displayed.
            How exactly do I do that?
            • #21
              Right click on the top row and select what you want in the display. The list is long so you have up an down arrows to scroll it.
              • #22
                Ah, there it is!! A thousand thanks, good sir. :)
                PS:
                Pat, I don't know if that's you, but the Nvidia 3090 and and BM Decklink 4K 12G Extreme was delivered today and will be installed this week. Waiting to see what happens at CES and then will decide on a 10-bit OLED HDR display of some sort.
                • #23
                  I will be looking at some of the micro-led TV's that may offer OLED like performance with no burn-in problems.
                  Ron Evans
