I cannot find it! Is there a quick method of resetting everything back to the initial installation settings? On initial installation I made a few wrong choices - some of which cannot be undone - "Generic OCHI" , for example. Or does this have to be done through an Uninstall/Re-install process? Thanks for any help! Peter Knight
Reset Edius 9 Pro to Default Settings
Everything can be undone or reset but not be pushing one button. What is the OHCI issue? Checkout https://www.videoproductions.com.au/...-settings.html
Generic OHCI capture is possible once you make a Device preset in system settings, hardware
to reset all settings to factory, create a new profile in system settings, then restart EDIUS and select the new profile, then go back to system settings and delete the old profileAnton Strauss
Originally posted by antonsvideo View PostGeneric OHCI capture is possible once you make a Device preset in system settings, hardware
Stay Safe in Aus, I suspect we are in for a bumpy few months.
Originally posted by DigitalDave View Post
HNY Sydney. Without wishing to teach the Pope about religion <GRIN>, I dont think the new profile changes ALL settings to default.
and happy new year and independence day for those who did not wish to be part of the EUAnton Strauss
Thanks for the information everyone. I had already gone through the route of creating a new Profile, restarting Edius, deleting the old Profile, restarting Edius, but alas - several settings remain "in-place" and cannot be undone, or deselected. "Use Generic OCHI" is one - once selected if cannot be "unticked", so on each Edius start I get the annoying "Changing to software" message. OK, I can turn off the message in the settings, but it would be nice to be able to hit a "Factory Default" button and know that I have a clean install.
I have to admit that I'm only evaluating a Trial Version of v9 Pro, and was hoping to purchase v9 along with the free Upgrade path to v10 (sorry, "X"), but that Upgrade looks as if it won't be extended after Dec 31st..... I've emailed Edius.net over this, but not had the courtesy of a reply. v9 is still being offered at the same price as "X", but at the moment it looks as if some important items have been removed from "X", and I'm unsure if my CPU will be effective with "X", so if I do go with v9 Pro, and then find that "X" may be suitable, I'm going to have to fork-out another £185.00 for an Upgrade. Ho hum, things are never easy with computer software!
Keep safe everyone,
Regards
P'Nut
Originally posted by PetePNut View PostThanks for the information everyone. I had already gone through the route of creating a new Profile, restarting Edius, deleting the old Profile, restarting Edius, but alas - several settings remain "in-place" and cannot be undone, or deselected. "Use Generic OCHI" is one - once selected if cannot be "unticked", so on each Edius start I get the annoying "Changing to software" message. OK, I can turn off the message in the settings, but it would be nice to be able to hit a "Factory Default" button and know that I have a clean install.
Keep safe everyone,
Regards
P'Nut
OHCI can't be disabled as mentioned when no third party hardware exists
OHCI does not support any frame size higher than 1440x1080 that is why you receive a warning, but the warning is uselessAnton Strauss
