Storm Pro SDI capture without sound in Edius 9
  • Storm Pro SDI capture without sound in Edius 9
    Hello everybody!
    I have a problem with two custom PC with Storm Pro cards (Windows 10, Edius 9). If i try to capture video in 1920x1080 @ 59.94i the file is ok (video and audio).
    But when i try to capture in 1920x1080 @ 50i only capture the video.
    The SDI cable is the same. And i tested the signal with a SDI monitor and it has sound. The card don´t recognizes it.
    The capture presets are basically the same, only changes the 59.94 by 50.
    The project is in 1920x1080 @ 50i.
    Do you know what can it be? any ideas?
    Thanks!
    go to system settings, device preset, select the 50i preset and check the audio section to see if all ok
