help?
  • help?
    Started up edius 9.53 wg and received this message...the gv license manager version is not the latest error code 3.22AB0.4EF0
    Please help if you can?
    Thank you
    Dano
    uninstall 9.53 and do not deactivate
    uninstall the GV license manager
    empty Temp folder
    restart PC
    install 9.54 (latest version)
      Thank you Anton. Will this erase my effect preset settings?
        no, it won't
          Thank you. Will try it tonight.
            Why don't you save (export) all of your presets to a safe location for future use if needed?
              PS....good idea, with my bad luck. Can you do it without the program opening?
              Dano
                Thanks for saving me.......again Anton. I really appreciate it.
                Dano
                  Dano
                  No. But once in, Go to the Effects Tab and Right c\Click on the effects (or folder) where you keep any user presets and choose Export. I have created a Favorites folder in the Effects tab and keep any presets I create in that folder. That is the one I export.
