EDIUS X render queued not running
  • EDIUS X render queued not running
    Hi
    I have problem. Probably after windows update net. framework, when i want to render it is queued and it not go futher.
    What to do? I unistaled update, then edius, and reinstal edius but it wont help.
    WS: Edius 6.55 / I5-2500K 3,3Ghz / ASUS P8Z68 deluxe gen3 / RAM: 8GB 1866Mhz / ASUS GTX550Ti 306.97 / Virtu green 1.2.114.21767 / 4x2TB WD / Win 7home 64bit / Neat Video / Adobe Premium Production CS6 / 3ds Max 2014
    Cam: Sony EX1r / Nikon D750 / GoPro 3 black
    on timeline simple file h.264 wythout anything, antivirus is only from windows.
      Hello
      I found what is a problem. Background render from timeline. Could anyone know how to clear this jobs. When i unplug disk, i got errors of rendernig jobs which was'nt on bacground job and gj monitor.
        Originally posted by Tofifik View Post
        Hello
        restart windows - always help in this case
          Not this time. I have done several restart cos unistall and install edius x and windows update .net
          For now help, unmount disk and waiting few minutes to all errors apears, and then stop.
            Are you running Edius X 10.10?
              Yes. Edius 10.10.6765. Windows without update 20H2 and KB4580419 (net framework 3.5 and 4.8). All bundle plugins installed. Quicksync enable.
              But the main goal to fix that is to find, where is possobility to clear all render tasks. Because i worked at 8 (2TB mxf files), and i rendered on timeline some cuted clips. Then i start to render to file, i cannot do that because "main" render go to status queued. I try anything, job monitor, turning off and on task i service, restarting few time, reinstall. The solution in this case was, unmount disk where was files. Then i got few error message that edius cannot render (any job monitor was empty), then i try render simple small file and it render it. So i start thinking what just happend, then i got second error with other file. When i connect again hdd, every things go as usully.
              So the problem is with (shitf+g) render on timeline, which render to much (whole file instead the selected part without any message, and listed position in job monitor).
                perhaps this will help
                https://forum.grassvalley.com/forum/...ilesin-edius-x
                  if there is background rendering happening, you just need to wait until it is done, then the export will start
