Edius X: Unknown error by starting a project containing a vignete filter(Vitascene).
  • Edius X: Unknown error by starting a project containing a vignete filter(Vitascene).
    When I start a project in Edius X that contains a vignette filter of Vitascene 4.0, I get the following error: Failed to playback Unknown Error 0x870 307D0 (0x870 307d0) and a red-black checkerboard appears in the play window.
    The error disappears after restarting edius but reappears after restarting my PC and Edius.
    Who can help me by solving this problem?
    My processor is Intel(R) Core(TM) i9-10900K CPU @ 3.70GHz 3.70 GHz and my display is connected to the motherboard (Quick sync)
    You do not have permission to view this gallery.
    This gallery has 1 photos.
    Can you post the exact verizon of Vitascene 4 so we can try to replicate?
      The vitascene version is 4.0.280.
        Thanks we will check if we can reproduce it.
        One other question. What is the asset that is applied to? Which format , codec and wrapper?
          attached pictures of project setting and properties of a clip
          This gallery has 2 photos.
            It kinda looks like the plugin didn't load on startup. Try it again and wait until Windows has finished loading
            before starting Edius X. See what happens.
              We cannot reproduce this currently. Can you give us a screen shot with the clips seen on the timeline.
                also, the exact vignette filter used
                  The vignette filter used is Black-Vignete #536.
                  Screenshot see attached Photos
                  it's exactly whether that vitascene doesn't start up properly at the start of edius x. What can I do?
                    I tested it and have no issue, but I may be using a later version Vitascene 4.0.285
                    This may not be publicly available at this stage
                      My problem is solved. When I start Edius immediately after the startup of my desktop, this problem occurs. When I wait a few minutes everything goes normally.
                      Apparently Vitascene needs some time to install itself in the background.
