Hello to all Edius editors
Is there any topic with Edius feature wish list?
Maybe it is time to create it?
By the way - another question - does Edius has a update schedule? monthly updates? or maybe quarterly?
In order to start, my current Wishlist:
- Audio waveform preview in preview window
- function to copy all audio settings/effects to multiple audioclips in one action
- ability to copy/paste multiple effect to multiple clips (and delete them from multiple clips selectively)
- recurrent clip use marker on timeline
- project export to (FCP or Adobe) xml format
- export sequence to project with different framerate
- exact match frame in "timecodeless" clips
- rightclick option on timeline clip - find in folder/explorer
- analog of adjustment layer
in GV job monitor:
- "rightclick" options:
remove task
find in explorer
if topic will be useful - i will add more from your posts.
if there is one already - show me please.
when we accumulative most of wishes - we will send them to [email protected]<a href="https://www.youtube.co...>edius.net</a>
maybe it will be better for all of us =)
Thanks in advance
in GV job monitor:
remove task
find in explorer
Thanks in advance
