EDIUS X or 9 ?
  • EDIUS X or 9 ?
    Needs more time for comparing the two versions...
    9 !!!
    It don't need AVX2 cpu
    • Ray Lenahan
      Ray Lenahan commented
      Editing a comment
      Same here . I got X and can't use it because of AVX2.... Disappointed
    It depends on your workflow. There are quite a few improvements. For me, the auto tracking with layouter, waveshell support and the auto correction in vst latency is worth the upgrade. If does take Windows 10 and their are minimum hardware requirements.
      I will not upgrade to Edius X until the shift+Q function is back.
      1ST SYS : INTEL I7-10700 / 32GO / 1 SSD NVME 512GO / 1xSSD 1TO + 2xHDD 12TO + 2xHDD 4TO / BMD Intensity Pro 4K / AMD RX-580 / Jog ShuttlePro2
      2DE SYS : INTEL I7-7700 / 32GO / SSD NVME 512GO / 2xHDD 8TO
      3DE SYS : INTEL I7-4790K / 16GO / SSD 512GO / 3xHDD 4TO
      4DE SYS : INTEL I5-4460 / 16GO
      5DE SYS : INTEL I7 2600K
      MONITORS : 2x27" WQHD IPS + 2 x 24" WUXGA IPS + 1xMon JVC 17" TM-H1750C + 1 TV 22" FHD + 1 TV 55" 4K
      SOFT : Win 10 Pro x64 - Edius Workgroup v9 - Vistitle v2.9 - Neat Video Den
        You will be wanting to upgrade soon.
          In my opinion, it would a good idea to pay for the upgrade now, even if you don't install it immediately.
          Also, I have 9 and X running happily on the same machine together, which allows analog capture from legacy devices in 9, and editing in X.
          A win-win situation!
          Regards,
          Jon
            It is not at all a solution to have the 2 versions on the same machine; on the contrary, you will have many problems especially if you decide to open version 9 projects where third-party plug-ins are inserted with EdiusX, not to mention if you run the "EDIUS.NET Setup Manager"
              I'm sorry but one should always read the requirements of a program. It was clearly stated that you needed AVX2 for EDIUS X. This is not unusual as newer versions require greater hardware capabilities.
                GrassValley_PS, can I downgrade from Edus 10 to Edius 9. Educatonal license. Computers in class don't have avx2
                  We have no control over that. You will have to contact whoever you bought the licenses from.
