Can't hear audio Edius 8
  • Can't hear audio Edius 8
    I am using Edius 8. Been shooting MP4 with my DSLR and when I add a file I have shot I am not hearing. I see the audio meter moving so I know there is audio there, I just can't hear it.
    The file is coming in a 48khz I believe. There really aren't and settings for audio on my Lumix G7 so I can't be sure.
    I have tried putting the sound on stereo and also mono in the channel map but doesn't seem to make a difference.
    Can anyone point me in the right direction.
    \My previous imports of adding a file have been with XDCAM and never had any audio problems.
    How are you montoring the audio? Do you have an I/O device?
      See if you are monitoring hardware or OHCI. Also check the small speaker in your windows display and make sure the correct speaker is selected.
        Monitor while recording? I am using a SD card reader to USB in.
        I do hear sound on the file when I play it in Media Player and PowerDVD. As a matter of fact I can hear the audio in all media players I have in software. Everything but Edius.
          Done. Again I hear the file in all media software except edius. It has to be a edius default setting I am missing.
            let me ask the questions via attached images
            what is the default audio device in control panel?
            what is the EDIUS preview device?
              For no reason that I can explain it's working again. All I did was relaunch Edius and I had audio.
              But I did get the settings you were asking about
              Perhaps an intermittent problem but thanks for your concern.
