Problem with Edius X not stopping on dropped frames
  • Problem with Edius X not stopping on dropped frames
    UPDATE.
    Here's a video showing the same Edius X installation doing what it should do with regard dropped frames. This just confuses the whole issue even more as nothing had changed but Edius X worked this time.
    https://youtu.be/C_C5qLWhKQI
    Here's a problem with Edius X clearly showing it not stopping on dropped frames. This does not happen when I use Edius X on its own in a different Windows boot setup.
    Can anyone from GV explain what is causing this?
    https://youtu.be/y-eUdHnSV2I
    Works here
    Stop on dropped frame.mp4
    My System: Edius Workgroup 9.51 & 10.0, Intel I9-9900K 3.60GHz Liquid Cooling, MSI Z390-A PRO MB, 32-GB Mem, GeForce GTX 1660 6GB GPU, BM Intensity Pro 4K Card, Win 10 Pro
      Originally posted by LewS View Post
      Works here
      [ATTACH]n557425[/ATTACH]
      It also works on my other installation but for whatever reason it clearly isn't working on this one.
        is it possible that the configuration of a computer in general could cause issues?
          when something differs between PCs, the first thing I try is a new EDIUS profile, if it does not help, I delete the profile again
            These examples are actually on the same PC, just different multi-boot options for different Edius X installs. Interestingly though, the problem didn't happen with a new project today????
