Titler Pro 7 Ultimate
    Jerry, I see the 1080ti on Ebay for around $400 to $500 with 11VRAM of memory. The GTX TITAN X has 12VRAM
    Win10 Pro64, EDIUS 9, Intel i7 8700K @4.9GHz/ OC,Asus ROG STRIX Z370-E GAMING Motherboard, Memory Corsair Vengeance LPX 32GB 4 x 8GB DDR4-2666 PC4-21300 ,Hard Drives all SSD M2 type 1 Samsung 960 EVO 250 GB, 1 Samsung 960 EVO 500GB, 1 Samsung 850 EVO 500GB, 1 WD 256GB, G-Drive USB SCSI Storage external drive 5TB for File storage, Nvidia GeForce GTX 980, Sony PMW-EX1R, Sony PXW-Z150.Vistitle, Newblue Titler Pro 4 & 5, Neat Video, Proshow Producer 9, TMPGEnc Movie Plug-in AVC for EDIUS.
      Personally, I think those prices are high. Prices for 1080-2080ti dropped at the announcement of the 3000 series. When supply wasn't there the eBay prices climbed again.
      i would wait for either a new 3000 card with 10-20GB of ram or until the price drops again on 1080-2080ti cards. A 2080ti with 11GB of ram for $400-$500 would be a better buy than the 1080ti for the same price.
      i don't know if there will be a 3070 with 10GB of ram made for $500.
        When the 3090FE 24GB is back in stock, it should be $1495. But, thacard might cause a bottleneck with your CPU.
        I would research that.
          So Jerry, then is it possible if you have a 11 to 24 GIG VRAM Graphic card you will be able to have real time on filters like Sapphire, transitions from Prodad Adorage and titles from NewBlue etc ?
            The GPU is just a part of a system. I can't predict if your system will get realtime performance on those items you mentioned.
            ​​​​​​There are many variables to consider.
            I can say that I get RT on certain Sapphire and BCC filters, not all. I do get realtime with the bundled Prodad V4 Edius version and TP7 for Edius.
            This is on a 4790k using 1080 10bit 29.97p files. If I go to 59.94, I lose RT with effects.
            • #21
              Jerry, I installed the Titler Pro 7 Edius version and I am getting real time with the Geforce GTX 980, I see the green circle loads first, then I apply the title and it works, the 3d ones gives that scrub to refresh pop up.
              • #22
                Does it retain the RT performance after a reboot?
                • oswaldbobb
                  oswaldbobb commented
                  Editing a comment
                  Yes it retains the RT performance after a reboot. I copied the 12 extra templates that came with Ultimate version into the Edius version, so I got back my monies worth, the templates sell for $59 each.
