Convert 25p to 50p using Optical Flow Edius X
  • Convert 25p to 50p using Optical Flow Edius X
    Apart from the rendering being slow on high quality Optical flow it did a very smooth conversion (no frame doubling) of the 25p to 50p.
    I note the CPU's are maxed out and it really isn't possible to get on with any other editing whilst rendering is going on.
    However one small section of the clip produced some weird results as the camera was panning past my car radiator grille as per screen SNIP attached.
    I tried it also on some walking forward material with some white fence posts on the left of the pathway and some frames had the top of the fence post have a ghost added in the direction of movement.
    Are these artifacts something that needs looking at?
    Sys4: Z10PE-D16WS MB 2xE5-2696 Xeon 64 active logical cores. EWG9. 64G RAM. Aorus GTX1080Ti. 55" Q7 1500 NIT HDR 4K TV/Storm 3G Elite/Decklink 4K 12G/8CH audio monitoring, Yamaha RXA-870 A/V. Sys1-3 EWG8 + RX-E1+HDBX1000 MIP in HP xw8600 2 x X5492 CPU 8 cores, 8Gig RAM, Quadro FX3800. All sys Fibre to central media pool - 5TB Axus Yotta RAID + QLogic Fibre Switch. Central VCR rack plus YUV & audio to viewing room with Yamaha AX1 7.1 100 watt per channel amp with 1000W sub 63" HD 3D Samsung TV
    yes, these have been reported since optical flow was added
      And I get similar artefacts on other programs with optical flow so I don't know if it can be "fixed".
        Yes, same here, I was using TWIXTOR in after effects before optical flow was introduced in EDIUS 8, it heavily depends on how shot was taken.
        Program has to create extra frames between existing ones based on that information. Depending on contrast, background (clear, detailed, blurred...), movement (pannig is more difficult), number of fps you get different results. Leaves on tress and woody background (if it's not blured) is very confusing and almost impossible, sand and water too, resulting in guessing wrong where all that similar almost blended detail is and where will be. Something moving from side to side is tricky too, moving from or to camera more pleasing. Fences almost always gets ghosting in my case too, depending how dense they are and how fast camera is moving.
          Optical Flow can be magical or not so good depending on the clip.
            Also try the highest quality setting. Sometimes you can get better results but it can take a while to complete.
              50i is still a thing - but everybody shoots 25 progressive and then wants 50P :)
              ¤ž€ß¤
