Edius X problem, it doesn't export layouter reframing settings.
  • Edius X problem, it doesn't export layouter reframing settings.
    UPDATE AND MORE INFO ABOUT THIS PROBLEM
    Here's something very strange Anton.
    My machine is multi-bootable, Edius X and 9 on one partition with a bunch of other stuff and then a second win10 install on the same NVMe boot drive with just Edius X and OBS and nothing else. MAC OS, Android, ChromOS, Linux and Openelec on a different multi-boot SSD. Not that the second SSD with the other OSs would cause any issues as they're just dumb data as far as an active Windows boot on the other drive is concernd but I pulled that drive anyway.
    The issues I've shown is when runing the Win10 partition with Edius X and 9 and other stuff on it.
    When I open and export the project on the other Win10 environment with just Edius X and OBS on it, the project exports properly.
    This may initially sound like some kind of corruption wih the project but a couple of things would say that's not the case. I have a number of projects doing the same thing and that's only out of the ones I've tested. The reason why I've only noticed the issue on a few projects so far is because I've not finished the others and wont know until I export my masters. It is also very unlikely that multiple projects would be corrupted.
    The second reason why I doubt it's corruption is becuase a different install of the same version of Edius X had seen the project differently.
    One other thing is that I do know for sure that this particular project was started on 9 and finished on X but I'm not saying that this is the cause of the problem.
    One thing is for sure though, the problem is definitely there as the video is showing, it's also happening on other projects and maybe more that I've not tested and this is definitely going to be a big problem when I come to finish other projects.
    I've never see this problem before on any other version of Edius.
    I'll do a proper full video walking through of the problem and explaining it in a couple of days. I'll put that one live on YouTube in case anyone, maybe GV, comes across it and can give some advice.
    I'm having issues with Edius X not exporting layouter reframing settings.
    I make some edits where I'm using layouter to re-frame some clips. These all playback fine when running through the edit but when I come to export the final edit the output file doesn't have the reframings that were done with layouter. Where the clips should show reframings, as they did when playing the edit, they simply revert back to the full frame on the export. This happens when exporting video, so far I've used NVENC, and it also happens when exporting stills, so far I've seen this on JPG files that I use as poster frames.
    Has anyone else noticed this?
    Here's a quick video showing the problem. I actually used layouter on this video to do close ups of various things going on but the output didn't have the layouter settings in it, you may need to click on the youtube link and watch it on youtube in full screen in 4K if you can't go full screen with the embedded version below.
    Works fine here. Could you list project details.
    My System: Edius Workgroup 9.51 & 10.0, Intel I9-9900K 3.60GHz Liquid Cooling, MSI Z390-A PRO MB, 32-GB Mem, GeForce GTX 1660 6GB GPU, BM Intensity Pro 4K Card, Win 10 Pro
      I'm in UHD 25FPS. Tried changing to 1080 but the same thing happened.
        Here are my project settings:
        Frame Size : 1920 x 1080
        Frame Rate : 29.97
        Aspect Ratio : 1.0000
        Field order : Progressive
        Video Channels : YCbCr + Alpha
        Bit Depth : 8Bit
        Color Space : BT.709
        I tried the layouter on video and jpeg stills doing both 2D and 3D moves and it worked fine with an h265/hevc (NVIDIA) export. Also changed the project to 10-bit and that worked fine also. Also tried an h264/AVC export which worked fine.
          Frame Rate : 29.97
          Bit Depth : 8Bit
          I tried the layouter on video and jpeg stills doing both 2D and 3D moves and it worked fine with an h265/hevc export. Also changed the project to 10-bit and that worked fine also.
          Thanks. My settings are basically the same except for PAL and 10 bit. I'll post a quick video shortly showing the problem.
            Frame Rate : 29.97
            Bit Depth : 8Bit
            Hi Lew. I've just posted a video showing the problem. You may need to view on YouTube and go full screen 4K to read and see things properly, I did do reframing to show the settings etc. but the export didn't have the reframing.
              is the title above the clip a quicktitle, vistitle or nb title?
                It's a quicktitle, although that doesn't seem to make any difference. This example video had a few reframes in it as well, zoomed into the project settings at the beginning, but they didn't show on the export and there were no titles.
                  Just tried opening the project in 9 and 9 wouldn't even recognise the layouter settings that were set in 10.
                    I duplicated exactly what you did in your video and it worked fine.
                    Could you start a new project and try again? Maybe the project is corrupted. I have opened projects created in EX in E9 and vice versa and all the effects work between them.
                      I have also tested all possible ways and no issue
                      there must be something unique to your project
                      could I see a screenshot of all settings within the layouter and also project settings with everything visible
                        I thought the same but it is happening on a bunch of projects not just the one. Out of interest, if you get time can you try it again but replicate it in a project you already have that’s got a fair bit of editing already in it but try the example further down the timeline maybe about an hour in.
                          It’s not just happening on one project it’s on a bunch of projects but could be even more, I’ve only noticed it so far on a few because they’ve been completed and exported.
                          I’m just in bed now but will do a more in-depth video tomorrow and will show the extra info you’re asking about.
                            what are you doing in bed at 5am :)
                              I know, why sleep when you could be editing :)
