missing used clip indicator
  • missing used clip indicator
    In a new project (EDIUS 9.52) the clips in the bin that are being used on the timeline are missing the indicator that shows they have been inserted on the timeline. This makes it difficult to know if I've already used a clip. Is there a setting that will bring this function back? I have looked at user and project settings but haven't found a solution.
    Hudson Valley, NY
    i7 8700K @ 3.70 Ghz/16 gb RAM
    windows 10
    284 gb SSD boot drive
    2 TB work disc
    2TB storage disc
    EDIUS 9.52.6031
    What view are you suing in the Bin? Clip should show it.
      With Edius 9 in the users settings You could tick it on or off,is Edius X different ?
      Edius 9.5 / X ,Win 10 home
      Asrock Phantom gaming 6,
      CPU Intel I9-9900K
      500 Gb M.2 Samsung SSD 970 Pro plus
      1 TB M2 Samsung SSD 970Pro
      SSD OCZ 256MB
      WD 4TB HDD
      2 Dell monitors UP2716D
        any clip that is on the timeline shows a green dot in the bin
        and if you view by detail, you can enable the timeline reference count column
          Got it...changed "view" to clip and there they were as usual! My operator error. Thanks for the input.
          Hudson Valley, NY
          windows 10
          2 TB work disc
          2TB storage disc
          EDIUS 9.52.6031
            I do however wish the green dot was bigger
              Me too :-)
              kurt
              SW: WIN-10/64 PRO (21H2-19044.2006), Firefox u.a.
              NLE: EDIUS-X(10.33.9356)-WG; RESOLVE-18.0.4.0005 Studio​​
              // Read > Test > Understand
